CM 4.2 & Unity 5.0 Language Packs
anthonymd
We are opening an office in Beijing and I needs some help with various languages on my CM and Unity. On Unity it shows that I am licensed for 10 languages.
Unity
1. How do I find out which languages I am licensed for?
2. Do additional packs cost $$$?
3. When loading languages on either server do the associated "user" interfaces (Cisco PCA and CUM User Options) load as well?
CM
1. How do I set up certain phones to load the PRC pack only.
Thanks.
Jaime Valencia
you're licensed for any available language for your version.
you should have received already a bunch of DVDs with the extra languages, if not. they're available at CCO
you need to manually set the language options as they do not change automatically
java
if this helps, please rate
java
