CM 4.3 and IP Phones 6901 and 6911
Does CM 4.3 support IP Phones 6901 and 6911 ?
1 ACCEPTED SOLUTION
No, you can find that info by just searching 6901 or 6911 on cisco.com and reading the product documentation.
Call-control  compatibility
The phones are supported  on Cisco Unified Communications Manager and Cisco Unified Communications  Manager Business Edition Versions 7.1.3 and later, as well as Cisco  Unified Communications Manager Express 8.0 and later using SCCP.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps10326/data_sheet_c78-584412.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
130
