CM 5.11, Attendant Console, Queueing & Voicemail
I have an issue at various customer sites. They are using AC for reseption to answer calls. They want queueing and in the evening want calls to go to the reception voicemail. I cannot add the voicemail (Unity conn) trunk to the hunt group as an always route member, it just doesn't appear as a valid DN or pattern in the list. I've added CFNA & CFBusy on the pilot DN and this works when queuing is disabled, but with queueing on the queue never times out to voicemail. Is there any way of setting up queueing to allow the end user to force calls to voicemail without queueing? Or a time-based hunt list so that evenings and weekends go straight to voicemail.
Your thoughts please.
1 REPLY
Hall of Fame Super Silver
Re: CM 5.11, Attendant Console, Queueing & Voicemail
Create either a DN or a CTI port with a DN that forwardAll to voicemail, then from AC pilot you'll be able to find it. You may need to press the Find More DNs button to locate the DNs as not all of them fit in the list. I just did it few days ago on CM 5.1.1b without issues.
Chris
96
