Community Member
CM 5 CLI check
I have version 5.04 I am connect to CM use SSH. I need to sftp a file from the server to my PC. Using the following Command:
file get tftp <filename>
what value do I need to enter for the download directory????
1 REPLY
Gold
Re: CM 5 CLI check
For download directory, if you want to store it on the under the root folder as configured on the SFTP Server you need to mention "/" without the quotes.
229
