05-05-2007 12:48 AM - edited 03-14-2019 09:19 PM
is the cm5 database completely locked down now or you can still run SQL queries against the database or create a new database under the structure as you could in version 4x?
05-05-2007 07:26 AM
I am not sure about creating a new database, but definitely you can run commands to add, update items in the database via command line. I have had to do that for some temp bug fixes.
Sankar
PS: please remember to rate posts!
05-05-2007 10:09 AM
To add to Shakar's note, you can run queries from the CLI using the command "run sql" to retrieve data from the database. Adding database is not allowed.
05-05-2007 11:34 PM
is there a copy of the database table names and schema anywhere?
also have you had any joy with using the file get method from the CLI? I keep getting " Error cannot contact SFTP server on port 22"
05-06-2007 10:26 AM
to know what DB and table CM contains, you can use the command "show tech tables" this is give u a DBDump in a text file.
Yes, I've used CLI to get files from SFTP server. Do you have an SFTP Server configured and accepting connections ?? You need SFTP Server to download a file from CM using CLI
05-06-2007 01:44 PM
If looking for a SFTP freeware server for Windows, try Freeftpd.
http://www.sofotex.com/FreeFTPd-download_L30099.html
10-02-2007 02:22 AM
There is a free IBM Informix ODBC driver here: http://www14.software.ibm.com/webapp/download/search.jsp?rs=ifxic
You just need to register a name and email address to get it. However how you configure the options (protocol/setnet/etc) I don't know but I think this is a good step to being able to use something a bit more friendly that the sql utils provided.
Anyone know how to configure the options?
10-25-2007 06:56 AM
Anyone figure this out yet?
10-25-2007 07:45 AM
I spoke to a TAC guy about this yesterday - he said they are getting a tonne of complaints about this.
