Community Member
cm 5 database
is the cm5 database completely locked down now or you can still run SQL queries against the database or create a new database under the structure as you could in version 4x?
Re: cm 5 database
I am not sure about creating a new database, but definitely you can run commands to add, update items in the database via command line. I have had to do that for some temp bug fixes.
Sankar
PS: please remember to rate posts!
Gold
Re: cm 5 database
To add to Shakar's note, you can run queries from the CLI using the command "run sql" to retrieve data from the database. Adding database is not allowed.
Community Member
Re: cm 5 database
is there a copy of the database table names and schema anywhere?
also have you had any joy with using the file get method from the CLI? I keep getting " Error cannot contact SFTP server on port 22"
Gold
Re: cm 5 database
to know what DB and table CM contains, you can use the command "show tech tables" this is give u a DBDump in a text file.
Yes, I've used CLI to get files from SFTP server. Do you have an SFTP Server configured and accepting connections ?? You need SFTP Server to download a file from CM using CLI
Re: cm 5 database
If looking for a SFTP freeware server for Windows, try Freeftpd.
http://www.sofotex.com/FreeFTPd-download_L30099.html
Community Member
Re: cm 5 database
There is a free IBM Informix ODBC driver here: http://www14.software.ibm.com/webapp/download/search.jsp?rs=ifxic
You just need to register a name and email address to get it. However how you configure the options (protocol/setnet/etc) I don't know but I think this is a good step to being able to use something a bit more friendly that the sql utils provided.
Anyone know how to configure the options?
Community Member
Re: cm 5 database
Anyone figure this out yet?
Community Member
Re: cm 5 database
I spoke to a TAC guy about this yesterday - he said they are getting a tonne of complaints about this.
117
