Community Member
CM 6.0 installation problem
Hello;
I'm trying to install CM 6.0 on a HP DL380-G4 Cisco compatible server. It passes the media check and starts disk and bios checks. But after that nothing happens. No error, no restart, no continue...
The last things i see are;
Machine passed harddisk checks
configuring 7835H-3400 machine
checking HP machine's BIOS version
RAID firmware version and configuration settings done
After these nothing happens. i waited for minutes and minutes but nothing changed.
Any idea?
Bronze
Re: CM 6.0 installation problem
As I remember, there is a problem with remote upgrade in version 6.0, so you need to burn a dvd. Put the dvd in the local dvd-drive in the CUCM then it shoukd work.
Community Member
We encountered exactly the same problem and we were using the DVD. We waited for around 40 minutes and eventually it kicked into life and continued. I suggest a bit more patience will probably see you right.
165
