Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CM 6.1 a kind of abbreviate dialing
Hello All,
I have 7 digits extensions, all started with 111 and I want that when a user dials XXXX call manager change it to 111XXXX. (In another partitions/site I have 222 and so on). I have tried to use a translation pattern XXXX that prefix 111 to called, but when I dial anything it matches in the first 4 digits and apply this translation pattern. Do you now a way to do this? Many thanks in advance.
1 REPLY
Re: CM 6.1 a kind of abbreviate dialing
If all of them are IP phones in same cluster then only way is TPs, if you're reaching phones via a GW, ICT, etc you can prefix the numbers in the route pattern.
Unless you're running CUCM 7.X where the checkbox for urgent priority can be unchecked that's the default behavior for TPs.
If you can't uncheck the urgent priority the only option is to create the translation patterns as exact as possible and not just XXXX to avoid matching something else.
ie if you use 9 for outside calls exclude it from the TP.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
120
