Community Member
CM 6.1 and High Traffic Try Again Later
Greetings,
We are running a CM 6.1.2.1000-13 BE system and just started seeing the "High Traffic Try Again Later" message appear on the display of a few phones. In one case the call was dropped as well. Checked all the logs on CM as well as voice gateways and don't see any errors. I found a post referring to this back on version 3.X and a memory leak on 4.1 but nothing newer.
Has anyone seen this or have any insight?
Cheers,
Rob
Green
Re: CM 6.1 and High Traffic Try Again Later
Hi Rob,
High traffic is normally because of System resources.
When you check CUCM SDI/SDL traces look for High Traffic and timestamps specially we need to see SDL Queues, it may be CPU,Memory.I/O or HW failure we dont known.
This may require more investigation
If you have details SDI, SDL traces and perfom logs for last re-ocurrance please open a TAC case with us so we can track this problem.
Community Member
We will open a TAC case. Thank you for your response.
Rob
572
