CM 6.1 Busy Signal
I have a CM 6.1 system with a 3845 H323 gateway with a PRI. When someone dials a vaild PSTN number that is unavaiable instead of getting a busy tone they get the Cisco message "your call can not be completed as dialed"
Is there anyway to disable the Cisco voice message so you get the actual busy signal?
Re: CM 6.1 Busy Signal
You can try excluding the Annunciator service from MRGLs from devices (Phones, gateways etc.
Thanks for the reply, I tried that and it didn't seem to make a difference.
Did you ever figure this out? Running into the same thing and looking for an answer.
I don't believe I ever did, sorry.
149
