CM 6.1 Call Pickup Group Notifications not working.
We recently migrated from CM4.2 to 6.1 and now our Call Pickup notifications are not working. If I push the pickup button on a group phone I can answer the call but there is no audio or visual notification on the group phone that a call exists.
The audio and visual notifications are enabled in CM for the Pickup Group and timer is set to 6.
Any ideas?
Re: CM 6.1 Call Pickup Group Notifications not working.
Make sure the partition for the pickup is available at the line CSS
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks, the extensions were not in the same CSS.
got the same problem with upgrade from 6.0.1 to 6.1.2....solved setting the partion to none in the call pickup group
130
