CM 6.1 csa
Hi, got two questions aboug csa on CM 6.1
1) Is CSA installed part of the CM installation?
2. How do we upgrade CSA if required?
Hall of Fame Super Silver
Re: CM 6.1 csa
1) Yes
2) You dont upgrade it, it gets upgraded along with CM upgrade.
HTH,
Chris
Re: CM 6.1 csa
CSA is installed automatically from version CUCM 5.x and later.
Cisco recommend that you verifying on CCO whether you are running the latest release of CSA by checking available downloads on CCO, a CCO login will be required:-
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
The following URL details all stand alone CSA agent version matrix:-
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5707/ps5057/prod_technical_reference09186a00805106b4.pdf
This document states that 5.0.0.229 is the version automatically installed on CUCM 6.x. You can verify this by using the CLI command 'show packages active csa'.
All this information can be found in the following document link:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/csa/7_0_1/instcsa.html
Allan.
149
