CM 6.1 services stopping
I have recently installed CM 6.1 in a VMWare environment for testing. The install went smoothly, but I am having issues now.
There are several services that will start, but then they shut down after less than a minute, including the Call Manager and TFTP services.
All I have done on this is to change the Call Manager name from localhost to the IP address. I have tried restarting the license server and also rebooting the server to see if that helps.
I am using the starter license it comes with.
I don't see anything in the trace files since the services drop before anything can talk to them.
I can start the service manually, but it stops again after less than a minute.
Are there any logs I can look at to see what might be causing this?
1 REPLY
Re: CM 6.1 services stopping
If I change the hostname back to localhost from the IP address then the Call Manager and TFTP services stay running, but the phones still won't register.
I get the initial TFTP transfer for the .cnf.xml file, but I am guessing it is telling the phone to register with localhost so it isn't going out to the CM.
Are there any other changes I need to make besides the server name in system->server to use the IP address?
225
