CM 6 Changing DNS
I have a new CM6 cluster i am installing. Is it possible to change the DNS settings on one of the servers? I installed DNS servers on one of the servers, and i want to disable it since the pub doesn't have dns enabled.
1 REPLY
Re: CM 6 Changing DNS
I figured it out, and just wanted to share.
I ended up enabling DNS on the publisher. There may be a way to do it through the GUI, but i was only able to find it through the command line.
I first specified the domain server:
set network dns x.x.x.x
Then specified the domain:
set network domain xxxx.local
119
