CM 6.X - Caller ID displays 301 401 501 for international calls
We have Cisco 2851 Voice Gateways configured as MGCP connected to PSTN (ISDN Line). When we make international calls via PSTN the caller id displays 301, 401, or 501. We are running CallManager 6.X. Any help would be greatly appreciated.
Re: CM 6.X - Caller ID displays 301 401 501 for international ca
have you already configured calling number transformations???
or have you set the external phone mask to use it in the route pattern??
Or configured this at route list level or GW level???
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Silver
Is this only happening on international calls?
If so review your Route pattern configurations as well as route lists if different ones are used for LD vs Int.
HTH,
Chris
Chris,
It is only happening on international calls but the LD/Local route lists are configured identical from what I can see. The phone company said I do not have E.164 enabled for the numbering plan. I do not see a option to enable though.
What about the route patterns? Are these PRIs? If so, what does debug isdn q931 show?
Chris
Here is output from call to India from US.
000575: .Jan 6 18:08:24.651: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref
= 0x00D3
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98394
Exclusive, Channel 20
Calling Party Number i = 0x2081, '610*******'
Plan:Unknown, Type:National
Called Party Number i = 0xA1, '01191444*******'
Plan:ISDN, Type:National
000576: .Jan 6 18:08:24.979: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 call
ref = 0x80D3
000577: .Jan 6 18:08:28.559: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callr
ef = 0x80D3
Progress Ind i = 0x8188 - In-band info or appropriate now available
000578: .Jan 6 18:08:30.839: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callre
f = 0x80D3
000579: .Jan 6 18:08:30.847: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 ca
llref = 0x00D3
Right now your international calls are being marked as Plan: National and Type:National. You can change this on your serial interface of your PRI with isdn map address
Look at the following
isdn map address 011* plan unknown type unknown
This is not going to work with MGCP gateway, you need to make the changes on gateway configuration on CallManager rather than the gateway.
HTH,
Chris
You are right, i missed the point that he is using MGCP
I have a very similar issue. Is there a fix in MGCP?
607
