CM 7.1 and 6608/VG200 support
I cant find any info on what happens to the 6608 and VG200 during an upgrade t
o CM 7.x.  Are these devices supported ad will they still work after the upgrade from 4.1 to 7.1?
1 REPLY
Re: CM 7.1 and 6608/VG200 support
Both the 6608 and VG200 are supported even in CUCM 8.0.
Note that the VG200 itself is not TAC supported any longer and the 6608 has RMA only support through August 25, 2012.
122
