Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CM calling CME/CUE via VOIP
I have a customer with a CM site and a CME/CUE site. When I call from the CM site to the CME/CUE via VOIP I get a fast busy when it hits the call-forward noans timer. I imagine I am missing a dial-peer somewhere, but looking for some direction of what would be needed to make this scenerio work. Intrasite calls work fine, just leaving a VM if the CM is calling the CME side.
1 ACCEPTED SOLUTION
Re: CM calling CME/CUE via VOIP
This is likely a transcoding issue. When calls get forwarded to CUE they are changing Codec from g729r8 to g711. You need to register a sccp transoder to the cme to perform this function for you.
Here is an example
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce15.html#wp1012080
1 REPLY
Here is an example
319
