Community Member
CM Inter cluster trunks with Voice Gateway..
I have CallManagers & Callmanger express in many sites, all the local extensions are starting from 1 (1XXX). I want to enable calling between sites through VoIP. What is the best practice? Did somebody did this configurations before?
Please check the attachment for further understanding.
1 ACCEPTED SOLUTION
Community Member
Re: CM Inter cluster trunks with Voice Gateway..
give access number for each locations and using discard digits discard the access number in route pattern.
Community Member
Do you hav a ccm in all sites if so u can use intercluster trunks otherwise u have to use dial-peer in GW's
create intercluster trunk with remote cluster IP and select that trunk in route pattern
route pattern eg:511.1XXX and there is an option for discard digits select "predot" there
Community Member
I have Callmanager in big sites & callmanager express in my small sites. but all the site extesnsions are starting from 1XXX
Community Member
261
