CM platform access with plink.exe
Has anyone been successful at scripting ssh commands for CM platform access? I'm trying the plink:
plink -ssh -v -pw pass administrator@1.1.1.1 show status
but I get this:
C:\Documents and Settings\Administrator\Desktop\audio>convert
stty: standard input: Invalid argument
Command Line Interface is starting up, please wait ...
Exception in thread "main" java.lang.NumberFormatException: For input string: ""
        at java.lang.NumberFormatException.forInputString(NumberFormatException.
java:48)
        at java.lang.Integer.parseInt(Integer.java:470)
        at java.lang.Integer.parseInt(Integer.java:499)
        at sdMain.main(sdMain.java:610)
Copyright Cisco Systems 2006-2008
Super Bronze
I tried that a couple of years back, and failed.. it doesn't seem to like whatever Cisco have done when replacing the shell...
What info are you trying to retreive, and for what system? There may be another API or management option that could provide the info..
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: CM platform access with plink.exe
Roman, have you resolved your problem with plink ?
I'm also trying to connect with it.
I had the same problem I resolved with the following tricks...
I'm able to connect with this command and execute show status for example :
plink.exe -ssh administrator@10.11.12.13 -pw "password" -batch < plink-command.txt
In "plink-command.txt" I have this :
" -> Begin of file
show status
" -> End of file
/ ! \ You have to do an empty line at the end of the file in order to work.
At the moment, I'm unable to send a second command...
If you have find another way, I would be happy to hear about it !
Thanks Benoit, worked like a champ!
1259
