CM TSP Version
Can someone tell me how I can find my TSP version for CM 4.2.3?
Re: CM TSP Version
One way would be to log into CM and go to " Application" and then download the "Cisco Telephony Service Provider" Plugin. When you click on the executable on your machine, it will tell you what the TSP version you will be installing is. You can then cancel the install.
* Please rate helpful posts.
Re: CM TSP Version
Ok so my CM ver of TSP is 4.2 and my unity TSP ver is 8.2.1 is there a sheet that shows if these tsp match up or not?
Hall of Fame Super Red
Re: CM TSP Version
Hi Daniel,
This is a good reference;
Supported Version Combinations for Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified Communications Manager
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html#wp51076
Hope this helps!
Rob
155
