CM upgarde
Dear All,
I am running CallMgr 6.0.1...i need to upgrade the version of my CallMgr...any pdf file will be very helpful to me...
thanks,
malik
Re: CM upgarde
Hi Tiger_401,
please see the link below, depending on the upgrade path you will need to determine which pdf is applicable to your install.
This will depend on what version you are upgrading to.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guides_list.html
HTH, Please rate
Justin
Re: CM upgarde
Although a good doc being shared by Justin,you can check this URL for upgrading from 6.0.1 to 6.1(3)...and also it has the link to find the upgrade paths...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_3/cucm-rel_note-613a.html#wp706585
Kumar
Re: CM upgarde
What version are you trying to upgrade to?
Re: CM upgarde
hi,
currently i m running CM v6.0.1...please advice me which CM version is more reliable and stable for that i can upgarde it...and also send me the upgrade procedure for that version.
Awaiting your reply,
Re: CM upgarde
Hi tiger,
You can find all related topics regardings your ccm 6.0.1 in the following link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/docguide/6_0_1/dg601.html
each topic will take you through a cisco document which will help you om your plan
It contain this also:
Upgrading Cisco Unified Communications Manager, Release 6.0(1)
Wish this be hepful
106
