CM upgrade from 4.1.3 to 6 to 7
I have CM 4.1.3 on my LAB MCS 7825. Can some one point me to the correct procedure to upgrade from 4.1.3 to 6.0 ? Eventually I will upgrade it to 7.
1 REPLY
Re: CM upgrade from 4.1.3 to 6 to 7
open the proper guide:
Cisco Unified Communications Manager (CallManager)
Install and Upgrade Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guides_list.html
there are plenty of posts on this, please use the Search NetPro function to look
java
if this helps, please rate
java
www.cisco.com/go/pdi
121
