CM upgrade from 8.0 to 8.5 failed
I have a client trying to upgrade from 8.0.3.20000-2 to 8.5.1.13900-5 but he keeps getting an error . He downloaded the file from Cisco.
Errors:
12/28/2011 14:00:46 filter.sh|Current version is 8.0.3.20000-2|<LVL::Debug>
12/28/2011 14:00:46 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_ANN.tar"|<LVL::Debug>
12/28/2011 14:00:47 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_ANN.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
12/28/2011 14:00:47 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_BAT.tar"|<LVL::Debug>
12/28/2011 14:00:47 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_BAT.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
12/28/2011 14:00:47 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_CCMDB.tar"|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_CCMDB.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_CCMPREFS.tar"|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_CCMPREFS.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_CDPAGT.tar"|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_CDPAGT.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
12/28/2011 14:00:48 filter.sh|Processing token "2011-12-02-02-00-02_UCM-PUB_CCM_CEF.tar"|<LVL::Debug>
12/28/2011 14:00:49 filter.sh|INorOUT=OUT 2011-12-02-02-00-02_UCM-PUB_CCM_CEF.tar: No match.  This filename is not recognized.  Renaming files is not supported.|<LVL::Debug>
UB_CCM_TFTP.tar" result="7"/>|<LVL::Debug>
12/28/2011 14:01:28 file_list.sh|(CAPTURE)     <FilteredItem type="" file="2011-12-28-02-00-12_UCM-PUB_CDR_CAR_CAR.tar" result="7"/>|<LVL::Debug>
12/28/2011 14:01:28 file_list.sh|(CAPTURE)     <FilteredItem type="" file="2011-12-28-02-00-12_UCM-SUB1_CCM_CDPAGT.tar" result="7"/>|<LVL::Debug>
12/28/2011 14:01:28 file_list.sh|(CAPTURE)     <FilteredItem type="" file="2011-12-28-02-00-12_UCM-SUB1_CCM_TFTP.tar" result="7"/>|<LVL::Debug>
12/28/2011 14:01:28 file_list.sh|(CAPTURE)     <FilteredItem type="" file="2011-12-28-02-00-12_drfComponent.xml" result="7"/>|<LVL::Debug>
MD5 7f:9c:c7:9a:ee:23:54:23:5c:a1:ec:34:c2:b5:84:4f
ILOG_FILE="/common/log/install/install_log_2011-12-28.14.00.45.log", ILOG_RESULTS_FILE="/common/log/install/upgrade-results.xml"|<LVL::Debug>
12/28/2011 14:07:54 upgrade_manager.sh|Checksum the upgrade from /mnt/source|<LVL::Info>
12/28/2011 14:07:54 upgrade_manager.sh|Calling sha1sum -c /common/download/8.5.1.13900-5/checksum_file|<LVL::Debug>
12/28/2011 14:09:50 upgrade_manager.sh|Checksum failed (1). Examine /common/log/install/capture.txt for failure.|<LVL::Error>
12/28/2011 14:09:50 upgrade_manager.sh|Cleanup RAM disk|<LVL::Info>
12/28/2011 14:09:50 upgrade_manager.sh|Unmount /common/mnt/product_img|<LVL::Debug>
12/28/2011 14:09:50 upgrade_manager.sh|Cleanup mounted DVD or ISO|<LVL::Info>
Any help would be much appreciated.
Hall of Fame Super Silver
Were the files merged into a single file?  Was checksum OK?
Chris
Check whether the name of the file is changed after merging? The name should not be changed.
There was only one file to download.
UCSInstall_UCOS_8.5.1.13900-5.sgn.iso . It didn't come in parts.
Re: CM upgrade from 8.0 to 8.5 failed
Was the checksum valid? Have them compare it to what's in the readme.
That's what I suspect . The MD5 I got from those errors was 7f:9c:c7:9a:ee:23:54:23:5c:a1:ec:34:c2:b5:84:4f but the MD5 checksum in the original download section is 22cb5ad5bfe78e184e93b233721211a1.
I've told him know about the checksum.
Will let you know if that is the issue causing it to fail
Thank you
yeah, have them download it again and check the MD5 checksum before continuing with the upgrade.
HTH,
Chris
Yes you were right it was the MD5 checksum issue .
He downloaded again and did the hash calculation and it came out to be right
Thanks for your help
glad it worked, please rate helpful posts to help other users in the future.
843
