CM ver5.x vs ver6.x vs ver7.x
tom_chan
Simple question on OS platform
What are the supported OS platform on 5.x, 6.x and 7.x?
Rob Huffman
Hi Tom,
All three versions use a "Cisco provided" Linux OS. All 4.x versions are Windows OS.
Hope this helps!
Rob
chadlincoln
Level 3
Level 3
They run on Linux, but the installation is just one process. You don't have to install any OS then install CM. You just run the disk and it installs everything, including the Linux platform it needs.
Please rate if this helped.
