CM ver5.x vs ver6.x vs ver7.x
Simple question on OS platform
What are the supported OS platform on 5.x, 6.x and 7.x?
Hall of Fame Super Red
Re: CM ver5.x vs ver6.x vs ver7.x
Hi Tom,
All three versions use a "Cisco provided" Linux OS. All 4.x versions are Windows OS.
Hope this helps!
Rob
Bronze
They run on Linux, but the installation is just one process. You don't have to install any OS then install CM. You just run the disk and it installs everything, including the Linux platform it needs.
Please rate if this helped.
147
