CM version on new MCS7835H2-K9-CMC1
Does anybody know if CM 7.0(1) or 7.0(2) pre-loaded on the new machine from Cisco? Thanks!
Bronze
Re: CM version on new MCS7835H2-K9-CMC1
I have never seen software "pre-loaded" on any Cisco server. Typically, you buy the hardware and software separately. Then you are shipped the server, CD's/DVD's, and licenses separately.
I simply looked the model on CCO and found this:
• MCS7835H2-K9-CMC1 (preloaded with Cisco Unified Communications Manager 7.0)
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd8056e623.html
Please try searching CCO
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Steve,
Not sure if this helps, but the last MCS we received was loaded with 7.0(1) a short time ago :)
Cheers!
Rob
125
