Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CM4.1.3 to 6.1.2 migration
I've successfuly installed CM6.1.2 on new hardware (while leaving existing pub/sub intact)using dma and registered the lics. How do i start using the new server? I tried changing the ip address on one of my 7940's to point to the new server with no luck. I've read articles about post migration steps and lots of posts in here about upgrades/migations but i can't seem to find anything about how to proceed with a "swing migration". Any help is appreciated.
Marc
Re: CM4.1.3 to 6.1.2 migration
has the feature license been loaded?
Are all the services running??
java
if this helps, please rate
java
www.cisco.com/go/pdi
yes the feature lic has been loaded and the services are running.
you say you have registered the licenses. Which licenses do you mean ?
Do you have any DLU's showing in the License Manager ?
Cheers,
Matt
I entered the PAK number here https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?FormId=806 and cisco emailed me a lic which i uploaded to the new cm6 server. It shows i have 632 authorized and 614 used and 2 license servers authorized. Thanks again for your help.
-Marc
114
