CM4.2(3) - phone hang up timer
Hi!
Is there a parameter to configure the time the phone considers the call to be finished after the other party hangs up?
Ana
1 REPLY
Re: CM4.2(3) - phone hang up timer
Ana
look at Callmanager service parameter timers,
T305, 306, 308, 309 timers.
T305 Timer: This parameter specifies an ISDN Layer 3 timer for User (Disconnect Request) DISCONNECT sent, Network (Disconnect Indication) DISCONNECT without progress indicator sent. For exact timer definitions, refer to the Q.931 specification.
This is a required field.
Default: 30000
Minimum: 6000
Maximum: 150000
Unit: msec
T306 Timer: This parameter specifies an ISDN Layer 3 timer for Network (Disconnect Indication) DISCONNECT with progress indicator sent. For exact timer definitions, refer to the Q.931 specification.
Default: 30000
Minimum: 6000
Maximum: 150000
Unit: msec
T308 Timer: This parameter specifies an ISDN Layer 3 timer for User (Release Request) RELEASE sent, Network (Release Request) RELEASE sent. For exact timer definitions, refer to the Q.931 specification.
Default: 4000
Minimum: 800
Maximum: 20000
Unit: msec
T309 Timer: This parameter specifies an ISDN Layer 3 timer for User/Network (Any stable State) Datalink lost. For exact timer definitions, refer to the Q.931 specification.
Default: 90000
Minimum: 18000
Maximum: 450000
Unit: msec
275
