Community Member
CM4.2 - Change IP Phone Default Background Image
Hi!
I would like all the IP phones registered in the CM to have the logo company as the background image. Phone users have already that image as a choice in their phones. I would like to force that image on all phones from the CM instead being the phone users to have to choose the image. Is it possible to change the default background image or is there any other way that I could accomplish my goal?
Ana
Re: CM4.2 - Change IP Phone Default Background Image
good morning to you! this has been discussed before and unfortunately there is not a way at this time to set a background image. Maybe though you can set the idle value in your parameters so that after a certain time (1-2) seconds your logo will pop onto the screen until you exit. Some users though will find this annoying because they will have to exit the picture before doing anything else.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbfcfef
Community Member
Thanks for your help.
By the way, do you know if this will be possible for CM6.1?
unfortunately that's not available in any CUCM or CME release.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi javalenc!!!
Please your help,
About the issue if is possible to change the background image on all phones from the CM instead being the phone users to have to choose it ?? It´s still not posible or there are any way to do it?
Thanks a lot!!!!
Ivan Garrido.
Ivan this is a very common request:
Take a look at:
https://supportforums.cisco.com/message/3060726#3060726
Officially there's no way to push this from CUCM. But with some scripting and the use of the phone SDK you should be able to do it. Look at this great post.
http://www.netcraftsmen.net/component/content/article/70-unified-communications/791.html
Completely off the record I'm working on a small java tool myself  to automate this, but it should be a few days before anything is assembled.
555
