Community Member
Cm5.1 BLF
Ok,
I recently added a 7914 sidecar to a 7961 phone and programmed a bunch of BLF's to the sidecar so that the receptionist can see if the brokers are on the phone, this works fine on other phones, however on this one phone, it sees the buttons, but when the brokers are on the phones the buttons are not turning red like they should...
(both the phone and the DN's it needs to watch are in the same partition so it's not a CSS thing)
Just wondering if anyone here has seen this in the past before I start poring through CM traces....
Oh, CM 5.1 :)
Thanks in advance
1 REPLY
Re: Cm5.1 BLF
make sure both devices are in the same presence group and that the SUBSCRIBER CSS from the device with BLF configured can reach the monitored DNs
java
if this helps, please rate
java
www.cisco.com/go/pdi
102
