CM5 database errors (intermittent)
I have a CM5 system running for about 2 years with no problems.
Recently, I have database errors when making any changes via the Web GUI (Adding a phone/ chaning user passwords etc)
I get errors like "Update Failed / No permission to update" etc
Rebooting the server causes the problems to go away most of the time.
My Disk/active is at 94%
I have now turned all tracing off.
Is there a tool available to check the integrity of the informix database ?
Re: CM5 database errors (intermittent)
you can try the utils db_replication commands to check the DB
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks, I thought I already gave that a go, but will do so again.
BTW, I am running on a single server.
Hi, I am still facing this problem :-(
Any clues as to where I should start looking ?
I cannot even enable traces on the server !!
hi,
i wish i could help but my problem is just same as yours. The problem started this morning, also running ccm ver 5.1. Users cannot login, i cannot make changes, i get this msg "Update failed. Cannot read system catalog (sysprocplan)"
Please, can someone help, all search for solution has being fruitless.
thanks
189
