Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CM6.1 Find Devices to Add to Route Group
Hi!
I'm trying to create a new route group but the device I want to add as a member does not appear when I do the "Find". It's a trunk that is already configured under "Device>Trunk". Do you have any idea that justifies this behavior?
Best Regards,
Ana
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: CM6.1 Find Devices to Add to Route Group
ensure the trunk is not assigned directly to any route patterns.
Chris
Silver
I`ve seen this serveral times- does not always makes sense as it is not always true either but it seems to be if you have assigned the trunk to a RL, RG then you can only see it from the RL, RG
Chris
Hi!
The problem was exactly that it was already assigned to a route pattern.
It is solved!
Ana
149
