Community Member
CM6 and VG200s
Hi all. I'm just wondering if a VG200 can be used as an H323 gateway with CallManager 6. I would think that with H323 the model wouldn't matter at all.
Anyone know for sure?
Justin
1 REPLY
Re: CM6 and VG200s
VG224 can be configured for H323, MGCP and SCCP, VG248 is only SCCP
just found the link:
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a0080091de1.html
•Lower cost of ownership-The Cisco VG200 communicates with the Cisco CallManager using the Media Gateway Control Protocol (MGCP) or H.323 Version 2. It allows connectivity between a Cisco CallManager-based IP telephony system and legacy telephony equipment such as the PSTN, private branch exchanges (PBXs), and voice-mail systems. The Cisco VG200 provides a space-saving solution that can be managed remotely using network management applications such as CiscoWorks.
as you mention, CUCM version is really not relevant.
java
if this helps, please rate
java
www.cisco.com/go/pdi
103
