Community Member
CM6.X Attendant Console queue with VM rollover
I have a CM6.0.1 install with a receptionist using Attendant Console. Currently I have queuing enabled on the pilot with the operator line 1 as the first in the hunt list, with a CTI route point that goes to the AutoAttendant listed as the "always route" option.
My problem is that when the operator logs out of AC, calls are still being queued. They never get to the CTI route point. If I disable queuing, then it works fine, but having incoming calls queued is a necessity.
Any ideas why this happens? I assumed that when the operator logged out, the AC Pilot would skip over her and go right to the next option in the hunt list.
Community Member
Re: CM6.X Attendant Console queue with VM rollover
Anyone have any ideas on this one? I'm stumped.
Community Member
Chris,
I actually just posted another similar topic. I didn't find yours first. I am having the same problem, and don't know if this is the expected result or not.
I have a TAC case open, but have you figured anything out?
Community Member
Yeah my response from TAC was that with queueing enabled, even with the AC users logged out, the calls would be queued before rolling to the "always route" hunt group member. :(
156
