CM8.6-K9-UPG=
I am trying to find out what is included with the P/N: CM8.6-K9-UPG= but was not able to get the answer from Cisco TAC at all.The description for this P/N is not clear either. Basically I have a new MCS 7825-I5 server and would like to install the Linux OS and UCM 8.6 software on it.
1 REPLY
CM8.6-K9-UPG=
If I understand correctly, what you are going to get is  'permission' to use the PUT to upgrade a previous version that you do not have ESW/UCSS maintenance on to 8.6.
At $16k retail, makes maintenance look attractive...
CM8.6-K9-UPG=CUCM 8.6 Upgrade Kit for PUT Only15995.0
If you are running new, UCL would be the least expensive option at $10.5k with it's 50 seat minimum:
Top-level:
CUCM-USR-LIC    1    21 Days
configure:
LIC-CUCM-USR-A    50    21 Days
UCM-7825-86    1    21 Days     <<<--you can select up to 6 server licenses here at no additional cost
auto-added:
CUCM-PAK    1    21 Days
CUCM-USR    300    21 Days
UCM-7825-NODE    1    21 Days
CCX-85-CMBUNDLE-K9    1    21 Days
UCM-7825-86-KIT    1    21 Days
CCIE# 6771
463
