CMBE - Unity Connection - Login failed
I am installing the CMBE 6.0 (CM version 6.0.1.2000-3 and Unity Connection version 2.0.1.2000-337).
The application user is ccmadministrator.
The login to CM is ok, but when I try to access the administration page of the Unity Connection (user ccmadministrator and password), the page return to login page without any error message.
The serviceability page of the Unity also have the same problem.
I tried by bugs, but found none.
Any ideas?
Tks
Re: CMBE - Unity Connection - Login failed
I have this exact same problem. I've tried resetting the admin password and it doesn't help. I'm really at a loss on this and intend to open a TAC case.
Try the workaround for CSCsh98940 and see if you are able to log in.
Michael.
180
