CMBE6 and voicemail to Outlook email
Is it possible to get your Unity Connection voicemails to appear in your Outlook Inbox?
Re: CMBE6 and voicemail to Outlook email
You can setup a SMTP notification in your unity connection so that it will notify via an email if you have any new voicemail. Following is the reading
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration/guide/2xcucsag200.html
There is also licensed add-on for unity connection called as unity inbox and pca, which will allow to send an email with a link to unity connection host where you can listen to the messages. You can also integrate with your IMAP clients.
Thanks for reply. How does the IMAP work? Are there any docs to follow?
Here is a doc about PCA, which is portal gives you access 1. Unity Inbox, 2. Unity Assistant.
User can change their unity connection settings and listen/download voice messages.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/1x/user_setup/guide/us010.html
147
