CMC Code Hidden or Not on phone screen [CCM5.13]?
Dear All,
When a user dials a number that is routed through a CMC-enabled route pattern, a tone prompts the user for the client matter code. When the user enters a valid CMC.
The CMC should be Hidden or Show on phone screen? Or any option in CCM we can choose?
Any Cisco link to mention that?
Thanks for help!
  • IP Telephony
1 ACCEPTED SOLUTION
Green
Re: CMC Code Hidden or Not on phone screen [CCM5.13]?
There is no way in the current implementation to block CMC digits. During the design, DE team felt that the CMC codes could be
so varied for each end user. That masking the digits would cause a lot more headaches for the end user then it was worth.
FAC should do it.
Will check if we can update this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_3/ccmfeat/fsfaccmc.html#wp1058059
Green
FAC should do it.
Noted!
Thanks for information
124
