CMC & FAC with LDAP PIN
I have CUCM 9.1, integrated with LDAP, I have configured FAC for some users, so these is seperate PT and CSS for each user matching exact Route pattern for FAC, can I user user PIN (End User PIN) as FAC or CMC ? so users can change their PIN using user web page, also i noneed to configure seperate PT and CSS for each user,
Please guide,
Regds
Everyone's tags (4)
1 ACCEPTED SOLUTION
No, FAC and CMC codes are not synced with anything, you need to change them manually via CCMadmin.
You don't need a PT and CSS for EACH user, you just need them to dial via the specific RP which has them enabled.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
174
