CMC on Callmanager Express
Can any one tell me if its possible to have CMC (cliente matter codes) on callmanager express ?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CMC on Callmanager Express
Here you go.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesoftk.html#wp1015257
Of course the manual is incomplete in mentioning the feature only for 7940/60 phones, it works for any model.
Please rate post if it helps!
Yes, it is. The specifics, as usual, are explained in the "system administrator guide".
Can you post the chapter, i only find FAC not CMC.
Here you go.
236
