CMC vs FAC
What's the main difference between Client Matter Codes and Force Authorization Code ?
Re: CMC vs FAC
If I remeber correctly CMC you will have in DRS, so you can bill your client based on codes for exmaple. FAC simply blocks some patterns if youy don't have enough auth code.
Edit: Check this link just found it: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03cmc.html
Re: CMC vs FAC
You are right , 5 pints from me
915
