06-26-2014 11:05 AM - edited 03-16-2019 11:13 PM
Please let me how the end user can configure Speed dial in CME 10.0.?
The customer only has SIP Phones 89XX configured. Can you explain me or give me an hint how can I configure that ?!
Stefan
12-02-2015 04:26 AM
I removed voice register dn and voice register pool then create profile
Than add phone and create profile again.
I tried with factory reset also but couldn't find much communication on wireshark. Every time i press directory button on phone, i see one TCP packet and than all ARP packets.
Attached are the logs after factory reset and re-add phone.
12-02-2015 04:54 AM
Hi Ilana,
One last thing that i would suggest:
Voice register global
No service https
Create profile
Exit
Voice register pool X
Reset
Plz check if the above works.
Manish
12-02-2015 05:00 AM
I tried but still same.
11-30-2015 04:08 AM
Hi Ilana,
just to add the upgrade link that Manish Gogna described ... 7821 10.2(1)SR1.
Hope this helps.
11-29-2015 07:19 PM
The procedure to configure speed dials for SIP phones on CME is explained here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmespeed.html#pgfId-1034351
To define speed-dial buttons for Cisco SIP IP phones, perform the following steps.
