CME 10 with Cisco IP Phone 3905 SIP and LPCOR
I'm having problems with LPCOR in a CME 10 with SIP Phones 3905 and 4 FXO connected to PSTN analog lines. I have 14 users that can make calls to local numbers and long distance numbers. The onother users can only make calls between extensions. To provide the facility to managers and supervisors transiting to the factory environment and at any time hold a long distance call from any phone, we have created the LPCOR where only 14 users have a specific code with permission. When the LPCOR is applied to user they cannot make call each others (between extensions). I belevie that has something wrong in the configuration, Does anybody knows if need something more to be configured?
trunk group FXO_OUVIDOR
 description ***CALLS LCL & SERV & EMERG***
 hunt-scheme longest-idle both
 translation-profile outgoing CalledNumber
trunk group FXO_LPCOR
 description ***CALLS LD & INT***
 lpcor outgoing Trunk-PSTN
voice translation-rule 1
 rule 1 /^00800/ /0800/
 rule 2 /^00300/ /0300/
 rule 3 /^000/ /0015/
 rule 4 /^00/ /015/
 rule 5 /^0/ //
voice translation-rule 2
 rule 1 /^11/ //
voice translation-profile CalledNumber
 translate called 1
voice translation-profile VoIP-SP
 translate called 2
voice lpcor enable
voice lpcor custom
 group 1 end-user
 group 2 Trunk-PSTN
voice lpcor policy end-user
 service fac
 accept end-user fac
 accept Trunk-PSTN fac
voice lpcor policy Trunk-PSTN
 service fac
 accept end-user fac
application
 package auth
  param max-retries 2
  param passwd-prompt flash:enter_pin.au
  param term-digit #
  param abort-digit *
  param user-prompt flash:enter_account.au
  param max-digits 32
username 525 password 7 <removed>
username 526 password 7 <removed>
username 527 password 7 <removed>
username 528 password 7 <removed>
username 529 password 7 <removed>
username 520 password 7 <removed>
username 521 password 7 <removed>
username 522 password 7 <removed>
username 523 password 7 <removed>
username 524 password 7 <removed>
voice register pool  1
 lpcor type local
 lpcor incoming end-user
 lpcor outgoing end-user
 id mac B000.B4D8.XXXX
 type 3905
 number 1 dn 1
 dtmf-relay sip-notify
 username user1 password 1234
 codec g711ulaw
voice register pool  2
 lpcor type local
 id mac B000.B4D8.TTTT
 type 3905
 number 1 dn 2
 username user2 password 1234
 codec g711ulaw
voice-port 0/0/0
 trunk-group FXO_OUVIDOR
 supervisory disconnect dualtone mid-call
 no battery-reversal
 cptone BR
 timeouts call-disconnect 1
 timeouts wait-release 3
 connection plar xxxx
 caller-id enable
voice-port 0/0/1
 no battery-reversal
 cptone BR
 caller-id enable
voice-port 0/1/0
 trunk-group FXO_LPCOR
 no battery-reversal
 cptone BR
 caller-id enable
voice-port 0/1/1
 no battery-reversal
 cptone BR
 caller-id enable
dial-peer voice 10 pots
 trunkgroup FXO_OUVIDOR
 description LOCAL-FIXO
 destination-pattern 0[2-5].......
 no digit-strip
dial-peer voice 11 pots
 description LOCAL-MOBILE
 destination-pattern 0[6-9].......
 no digit-strip
dial-peer voice 12 pots
 trunkgroup FXO_LPCOR
 description LDL-FIXO
 destination-pattern 00..[2-5].......
 no digit-strip
dial-peer voice 13 pots
 description LDL-MOBILE-8-DIGITS
 destination-pattern 00..[6-9].......
 no digit-strip
dial-peer voice 14 pots
 description LDL-MOBILE-9-DIGITS
 destination-pattern 00[12][1-9][6-9].......
 no digit-strip
Best regards,
Daniel
Daniel Sobrinho
Everyone's tags (1)
173
