I m using cme on cisco 1861. when i configured the router, i have been surprised that it can only accept 12 ephone ( but in the data sheet 15 !!)??
this is the show version of the router :
#show ver
Cisco IOS Software, C1861 Software (C1861-SPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:10 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
VOICE-SNC-LAVALIN uptime is 10 minutes
System image file is "flash:c1861-spservicesk9-mz.124-24.T3.bin"
States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.htmlIf you require further assistance please contact us by sending email to export@cisco.com. C1861-SRST-C-F/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K bytes of memory.
Processor board ID FHK142773Q7
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
12 User Licenses
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
Cisco
this is the all pack of the router :
ref | DESIGNATION | Qty |
C1861-SRST-C-F/K9 | 1861,8-user SRST or CME,CUE,4FXS,4FXO,8POE,SP Svcs,HWIC slot | 1 |
CAB-ACE | AC Power Cord (Europe), C13, CEE 7, 1.5M | 1 |
SCUE-ISE-7.0-K9 | Cisco Unity Express base release - 7.0 | 1 |
CUE-LANG-ENU | Cisco Unity Express - North American English | 1 |
CUE-LANG-FRA | Cisco Unity Express - European French Language Option | 1 |
SL1861-SRST-C-15U | 1861 CME/SRST + CUE Feature Lic upg from 8 to 15 users | 1 |
S186RSPSK9-12424T | Cisco 1861 IOS SPSK9-SPSK9 FACTORY UPG FOR BUNDLES | 1 |
MEM1860-128CF | 128MB CF for 1861 | 1 |
PWR-1860-220W | 1861 Desk Top Power Adapter 100-240VAC | 1 |
CCP-CD | Cisco Config Professional on CD, CCP-Express on Router Flash | 1 |
Please , could someone tell me what is exactly the problem?
Many thanks
Hicham
