cme 3.2 config assistance
I have added a 7970 phone but I am not getting a dialtone it is not picking up the extension either. It get the correct Ip address and CCME address.
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.1 255.255.255.252
ip virtual-reassembly
interface FastEthernet0/0
ip address x.x.x.161 255.255.255.224
no ip route-cache
duplex full
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip route-cache
duplex full
speed 100
interface FastEthernet0/1.1
description Data-Vlan
encapsulation dot1Q 1 native
ip address 192.168.10.1 255.255.255.0
no ip route-cache
no snmp trap link-status
interface FastEthernet0/1.2
description Voice-Vlan
encapsulation dot1Q 100
ip address 10.1.1.1 255.255.255.0
no ip route-cache
interface FastEthernet0/1.3
description Wireless-Vlan
encapsulation dot1Q 50
ip address 10.1.20.1 255.255.255.0
no ip route-cache
interface Serial0/0/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
interface Service-Engine1/0
ip unnumbered Loopback0
no ip route-cache
service-module ip address 10.1.10.2 255.255.255.252
service-module ip default-gateway 10.1.10.1
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.161
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
tftp-server flash:cmterm_7920.4.0-02-00.bin
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:P00403020214.bin
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.bin
tftp-server flash:S00103020002.bin
tftp-server flash:S00104000100.sbn
tftp-server flash:music-on-hold.au
tftp-server flash:telephony_service.html
control-plane
voice-port 0/0/0:23
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 100 voip
destination-pattern 4431111...
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
dial-peer voice 999 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:23
telephony-service
max-ephones 42
max-dn 144
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
web admin system name nrtc secret 5 $xxxxxxxxxxx
ephone-dn 1 dual-line
number 764
label test
call-forward busy 600
call-forward noan 600 timeout 28
ephone-dn 2 dual-line
number 765
label test
ephone-dn 3 dual-line
number 766
label test
ephone-dn 4 dual-line
number 767
label test
ephone-dn 5 dual-line
number 771
ephone-dn 6 dual-line
number 768
label test
ephone 1
mac-address 001E.7AC5.43D4
type 7970
button 1:8
ephone 2
mac-address C58E.423E.0001
type 7940
button 1:2
ephone 3
mac-address C58E.423E.0002
type 7940
button 1:3!
1 REPLY
Re: cme 3.2 config assistance
I see that you have assigned button 1:8 to the 7970 phone but i do not see any corresponding ephone-dn 8 configured
Try chnaging the button config to 1:5 and see whether it registers with an extension from 771
Narayan
82
