07-27-2007 08:35 AM - edited 03-14-2019 10:48 PM
I am replacing a SPE 310 in a ICS 7500 Chassis because the hard drive is going out on the old system. Does anyone know where I can find the Product Key information asked for during Call Manager Installation on the new server on the old server?
Solved! Go to Solution.
07-27-2007 08:39 AM
I don't remember getting asked for a product key. You mean the BTOO ......... number?
07-27-2007 08:39 AM
07-27-2007 08:42 AM
Yes I think so.
07-27-2007 08:48 AM
I found it.
07-27-2007 10:21 AM
Thx for confirming that it is the BTOO ..... number that is needed. :-)
07-28-2007 07:02 AM
Hi Guys,
Here is a link to the required info (number 2 on CCM list) just for future reference;
IP Telephony Application Product Keys
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801149d8.shtml
Hope this helps!
Rob
