CME 3.3 Compatible Command
Hi, i can't find the command '<no> auto-reg-ephone' at CME 3.3. I have gone through the command reference guide and found the command was introduced at CME 4.0.
What is the similar command at 3.3?
1 REPLY
Anonymous
N/A
Re: CME 3.3 Compatible Command
You cannot use auto-registration with CME 3.3.
180
