09-05-2007 11:55 PM - edited 03-14-2019 11:24 PM
We are running CME 3.3 and have issues regarding setting up extensions and phones using the HTTP browser. If we try to assign a button to the phone then click ok and save we just get errors on page in the internet explorer.
is this a java issue, if so what java should we use?
09-12-2007 06:17 AM
The ip http server command must be enabled on Cisco CallManager Express. However, if only https (ip http secure-server) is enabled, this command does not work. Both commands must be enabled.
09-18-2007 12:59 AM
we have the below config in the ccme router.
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
