04-03-2009 12:26 AM - edited 03-15-2019 05:17 PM
Hi all,
Is it possible to upgrade CallManager Express software to newer version?
We have router 2811 (2811, 256MB RAM, 64MB FLASH) with old CallManager Express 3.3 (IOS version: c2800nm-spservicesk9-mz.124-3g.bin), and needing to connect unsupported new types of phones Cisco 7911, Cisco 7961.
What is necessary for successful upgrade?
Best regards,
Miroslav Petkovic
04-03-2009 12:57 AM
Hi Miroslav,
Take a look at this compatibility matrix, shows you which versions of IOS support certain versions of CCME.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
04-03-2009 07:18 AM
I found IOS: c2800nm-spservicesk9-mz.124-23.bin.
When I try to copy this IOS on empty flash, process failed after 98% (33,546,240 bytes).
Result was same when I tried to load IOS from TFTP server, process failed after 98% (33,546,240 bytes).
After crossing a border of 33MB of loaded IOS, there starts to appear O signes (OOOOOOOOOOOOOOOOOO....),and it never ends, so I need to power cycle my router to make it load the old IOS.
Thanks!
BR
Miroslav
04-03-2009 07:40 AM
Hi Miroslav, do you have enough room on your flash? Thats possibly why its failing, not enough capacity. Take a back up of the old IOS, delete, then try again.
Darren
04-03-2009 08:23 AM
I tried to load IOS on empty flash, and it was same.
BR,
Miroslav
