CME 4.0(3) time display issue
We are running CME 4.0(3). The 7911 series IP phones are showing incorrect times. Alll other phone models ( 7940) work fine. We tried the time zone command. Upgraded the IOS to 12.4(4)XC7. Nothing helped. Current phone load is SCCP11.7-2-1-0S. This is driving me crazy..
Any suggestions??
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME 4.0(3) time display issue
Hi UCB,
These Firmware Loads are also available for your CME Version. It is a little hard to find sometimes (about a third of the way down the page) :)
cme-DST-phoneloads.zip
CME-Phone Loads with DST Fix
Contains - 8.0(4)SR2, 7931-8-2-1
From this link;
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
Hope this helps!
Rob
Please remember to rate helpful posts.....
Hi UCB,
This is likey a Firmware issue on the "Java Based" 7906 IP Phone model. These would be the minimum recommended versions;
Customers who are using the following Cisco Unified IP phone models:
7906
7911
7931
7941
7961
7970
7971-GE
are required to upgrade to the following phone firmware to display the correct time:
* CCME 3.X, 4.0 and 4.0(x) customers need to upgrade the phone load to 8.0(4)SR2.
* CCME 4.1 and 7931 customers need to upgrade the phone load to 8.2(2)SR1.
Hope this helps!
Rob
Rob,
thanks a lot for your reply. But the load mentioned by you seems to be only for Call Manager based phones. We are running CM Express.
Please correct me if I have missed something here.
Thanks & Regaards,
UCB Voice team.
Hi UCB,
From this link;
Hope this helps!
Rob
Rob,
Thanks for the suggestion. We are trying to implement this asap & will definitely keep you posted.
This new load has to be first put on the router flash, correct?
UCB VoIP Team.
Hi Team,
First off you are most welcome! Secondly, (yes the new Firmware will need to be copied onto Flash) Here's how;
SCCP: Upgrading or Downgrading Phone Firmware Between Versions
To downgrade or upgrade firmware versions on a Cisco Unified IP phone running SCCP, perform the following steps.
Prerequisites
Phone firmware for Cisco Unified IP phones to be connected to Cisco Unified CME, including all versions required during an upgrade or downgrade sequence, must be loaded in the ***flash memory of the TFTP server from which the phones download their configuration profiles. For information about installing firmware files in flash memory,
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. load phone-type firmware-file
5. create cnf
6. end
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1070512
Installing Cisco Unified CME Software
To install Cisco Unified CME in flash memory, perform the following steps.
SUMMARY STEPS
1. Go to Software Download site.
2. Download archive.
3. Extract files to be downloaded.
4. Use the copy or archive tar command to copy file to flash memory.
5. Use the show flash: command to list files in flash memory.
DETAILED STEPS
Step 1 Go to http://www.cisco.com/pcgi-bin/tablebuild.pl/ip-key.
Step 2 Select the file to download.
Step 3 Download zip file to tftp server.
Step 4 Use the zip program to extract the file to be installed, then:
a. If the file is an individual file, use the copy command to copy the files to router flash:
Router# copy tftp://x.x.x.x/P00307020300.sbn flash:
b. If the file is a tar file, use the archive tar command to extract the files to flash memory.
Router# archive tar /xtract source-url flash:/file-url
Step 5 Verify the installation. Use the show flash: command to list the files installed in in flash memory.
Router# show flash:
31 128996 Sep 19 2005 12:19:02 -07:00 P00307020300.bin
32 461 Sep 19 2005 12:19:02 -07:00 P00307020300.loads
33 681290 Sep 19 2005 12:19:04 -07:00 P00307020300.sb2
34 129400 Sep 19 2005 12:19:04 -07:00 P00307020300.sbn
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp998282
Hope this helps!
Rob
Rob,
Thanks a lot. In all probability, the change will be implemented on Monday. Hope to give you some good news then.
Many thanks,
UCB VoIP Team..
Rob,
Just wanted to inform that at last we were able to try out the new 7911 load as suggested by you on the CME router today. And bingo, all's well now. Thanks a ton for helping us to solve such a perpexing issue ( which even an IOS upgrade couldn't fix).
Take care & have a nice day.
Abhijit Das.
Rob,
UCB VoIP Team.
292
